Uwell Caliburn new products are coming!
Příspěvek od vapormo » 30 črc 2024 11:46
Uwell Caliburn has launched many new products recently. Today I will introduce four models to you: uwell dillon em, uwell caliburn gk2, uwell caliburn gk3, uwell caliburn g3, uwell caliburn g3 eco. Let’s take a look!
Details:
Uwell Dillon EM Kit has 900mAh built-in battery, 2.5ml capacity, and 25W max output. It features dual airflow system, 2A fast charging. Off White Micro Arc (limited edition, with only 5,000 pcs available), the exclusive CMF for Uwell Dillon, applies micro-arc oxidation to form an anti-corrosion and anti-scratch coating. it is an innovative anti-leak solution for a leak-free and hassle-free vaping.
Details:
Uwell Caliburn GK2 Vision Kit which is futuristically and cyberpunk decorated with a visually outstanding exterior, powered by a 690mAh integrated battery,18watt max output, 2ml vape juice. Compatible with CALIBURN G2 1.2ohm mesh coil, CALIBURN G 0.8ohm mesh coil, and CALIBURN G 1.0ohm coil. Constructed from zinc alloy, it inherits delicacy and compactness.
Details:
Uwell Caliburn GK3 Kit by utilizing a novel combination of Ultrasonic Welding and a U-Shaped channel mechanism, the leakproof has been significantly improved to 150%. Uwell Caliburn GK3 Kit is compatible with a 2.5ml Caliburn G3 cartridge with an integrated mesh coil. The internal battery is listed at 900mAh and rated for up to 25W output. The see-through cases achieve a futuristic look, and they can offer you mouth-to-lung satisfaction. The box-style Caliburn device is paired with a dual airflow system, and there has an LCD display screen is located on the front, which makes it easy to read the information about power, resistance, battery capacity, and puffs draw.
Details:
The Uwell CALIBURN G3 Kit, it's the first CALIBURN among the G series that supports 0.6ohm , max 25 W output made for RDL Freebase users and loose MTL Nic Salt users. The integrat - ed coil cartridge brings the features of leakage-proof and mess-free to the next level. You can experience a greater vaping with a flavor boost , constant stability and a throat hit.
Details:
The Uwell Caliburn G3 ECO boasts a detachable battery, making it an easy-to-recycle and eco-friendly choice. It is the first Caliburn among the G series that supports 0.6ohm, max 25W output made for RDL freebase users and loose MTL Nic Salt users. An additional 0.9ohm option is bundled for tighter MTL Nic Salt users. The U² Anti-leak Mechanism (combination of ultrasonic welding and a U-shaped channel) within the cartridge promises a 150% improvement in air-tightness. The ultrasonic welding would enhance anti-leak endurance while the U-shaped channel would store liquor condensate. Users don't have to replace the coil or get caught in ejuice leakage because of the integrated coil cartridge, which delivers a leak-free, mess-free and hassle-free vaping. G3 ECO Kit supports enjoyable and comfortable vaping because of a side refill mechanism, three trigger modes, and a 750 mAh battery. We still retain a 3-layer body framing design mechanism to ensure the highest possible protection for all internal components.
Re: Uwell Caliburn new products are coming!
Příspěvek od xanhast » 02 říj 2024 11:00
Příspěvek od xanhast » 02 lis 2024 18:54
Příspěvek od xanhast » 02 led 2025 15:25
Příspěvek od xanhast » 02 kvě 2025 15:44
