Comparison of four freemax series products
Příspěvek od vapormo » 28 říj 2024 12:03
As a relatively mature brand, Freemax has successfully launched a number of best-selling products. The four products I want to compare today are also their best-selling products: Freemax Marvos X, Freemax Maxus 3, Freemax Twister 2 and Freemax Marvos X Pro.
Details:
freemax marvos x 100W Kit consists of Marvos CRC Pod and Marvos X 100W Mod, which is the latest addition to the Marvos series and the first pod mod equipped with a fantastic lighting design. Marvos X 100W Kit adopts MS mesh coil, which can bring massive clouds and marvelous flavors for RDL and DTL vaping. The pod features 5ml e-juice capacity (standard), top fill design, and child resistant function. There are 5 theme colors and a random color options for you to custom the UI color. Marvos X supports 4 modes: Power, Smart, VPC, Bypass. Marvos X 100W Kit is powered by single 18650 external battery and FM chip 2.0. It is compatible with Marvos CRC Pod/Marvos DTL Pod/Marvos Glass DTL Pod/Marvos RTA Pod/Marvos DTL Pod Tank.
Details:
The freemax maxus 3 Box Mod Kit 200W combines full spectrum vaping and advanced FM COILTECH5.0/Double-D Mesh technology. Freemax Maxus 3 Kit features dual external 18650 batteries (not included), it offers an impressive 5-200W output range, complemented by a 5ml tank capacity with a top-fill design compatible with the Freemax M Pro 3 Tank. With dazzling theme colours, flashing light bars, and ISO 8317 Child Resistant Certification, this kit embodies innovation, style, and a commitment to safety for a remarkable vaping journey.
Details:
freemax twister 2 80W Kit is a rare variable wattage vape pen kit, which you can adjust the wattage by a simple twist of the base from 15W to 80W or turn fully anticlockwise to lock the device and prevent accidental operation. It consists of Fireluke 4 Tank equipped with FM COILTECH5.0/Double-D Mesh and Twister 2 Mod designed with a 3D embossed effect. Fireluke 4 Tank features a 5ml glass tube, a replaceable 810 drip tip, and a 510 base. Its top fill design is ISO 8317 Child Resistant Certified, which makes the tank super easy and convenient to fill and clean. Moreover, Twister 2 80W Mod is a variable wattage mod powered by a large 3000mAh built-in battery and charged with a 5V/1.5A USB Type-C cable. Twister 2 Kit now comes with six X Mesh Coils for various DTL vaping needs, and there's a wide range of X Mesh Coils on the way.
Details:
freemax marvos x pro Kit , Matched with a single 18650 battery, the Marvos X Pro kit can reach up to max 100w output of 4 kinds of vaping modes, of cause, thanks to the FM Chip 2.0, multiple protections will constantly escort you. Besides, the 5ml capacity Marvos CRC pod tank also plays an important role in the device, It takes the FM COILTECH5.0 Double-D mesh technology, the innovative parallel mesh structure, military-grade SS904Lmesh coil, and newly upgraded tea fibre cotton formula, joins forces in a strong create an optimal combination for you, perfect for enhancing the flavour and lasting experience.
Re: Comparison of four freemax series products
Příspěvek od xanhast » 01 led 2025 15:01
Příspěvek od xanhast » 01 úno 2025 13:57
Příspěvek od xanhast » 27 bře 2025 18:46
Příspěvek od xanhast » 27 bře 2025 18:47
Příspěvek od xanhast » 27 bře 2025 18:48
Příspěvek od xanhast » 27 bře 2025 18:50
Příspěvek od xanhast » 27 bře 2025 18:51
Příspěvek od xanhast » 27 bře 2025 18:52
Příspěvek od xanhast » 27 bře 2025 18:53
