Geekvape DIGI is newly launched!
Příspěvek od vapormo » 09 pro 2024 12:17
The Geekvape DIGI series has launched several products with very similar appearance and taste. In order to make it easier for customers to distinguish, I will take you to learn about these four products one by one: Geekvape DIGI Pro, GeekVape Digi Pro R, Geekvape DIGI Max and Geekvape Digi Max R.
Details:
GeekVape Digi Pro Pod Kit, Equipped with a 2000mAh fast-charging battery and a 40W max output, it delivers an exceptional vaping experience. Enjoy the 5mL pod capacity, interactive 0.96inch color screen, and RGB flowing light strip for a futuristic feel. With top airflow control, multiple activation modes, and compatibility with J Cartridge (Built-in Coil) & JR Cartridge (External J Coil) , the Digi Pro Pod Kit is designed for a seamless, customizable experience.
Details:
GeekVape Digi Pro R Pod Kit, delivers power and style with a 2000mAh fast-charging battery, a max output of 40W, and a spacious 5mL pod. Featuring a responsive 0.96inch color screen and an RGB flowing light strip, it's designed for both performance and flair. It offers Smart/Boost/ECO mode to bring you ultimate enjoyment. By adopting A-lock design, it can ensure the easy and safe use in a way. With top airflow control, multi-mode capabilities, and compatibility with the J Cartridge (Built-in Coil) & JR Cartridge (External J Coil), this kit offers a personalized, seamless vaping experience that's truly one-of-a-kind.
Details:
The Geekvape Digi Max Pod Kit comes equipped with a robust 3000mAh built-in battery, providing long-lasting power to keep you vaping throughout the day. With a maximum output of 80W, 1.47inch Interactive Touch Screen & RGB Flowing light strip,and shows all the vital information, With top airflow control, the Digi Max ensures a smooth and leak-free vaping experience.this pod kit is fully compatible with the J and JR Pod Cartridges, ready for holding at most 5ml ejuice.
Details:
GeekVape Digi Max R Kit is built with 3000mAh battery capacity, equipped with Geekvape Jr Cartridge of 5ml (replaceable Geekvape J Coil). Geekvape Digi Max R Kit has 80W max output, comes with 4 modes: SMART, BOOST, ECO, CUSTOM. Designed with upgraded airflow architecture, Digi Max R Kit features triple leak-proof and multi-layer airflow distribution tech, which offer you amazing vaping. An independent lock will secure your device with a gentle push. Geekvape Digi Max R Pod Kit is compatible with Geekvape J Cartridge (with built-in coil), Geekvape Jr Cartridge (replaceable Geekvape J Coil).
Re: Geekvape DIGI is newly launched!
Příspěvek od xanhast » 02 led 2025 18:26
Příspěvek od xanhast » 02 kvě 2025 19:06
Příspěvek od xanhast » 03 črc 2025 07:50
Příspěvek od xanhast » 03 srp 2025 20:32
