Disposable e-cigarettes recommendation
Příspěvek od vapormo » 06 kvě 2025 11:44
We have created a new category of disposable kits e-cigarettes on our website. If any customer has this convenient need, they can place an order directly and we will provide you with door-to-door delivery service.
Details:
Vapmod Sniper 25000 Disposable Kit features a 2-in-one options, you can switch between two different modes: MTL & DTL. It will provide extended vaping experience with 900mAh built-in battery and 22ml capacity. In addition, Sniper 25000 also features mega display, dual 1.0ohm mesh coils, and adjustable airflow. It will bring up to 25000 puffs.
Details:
Vapmod Space Trek 30000 Disposable Kit is powered by a built-in 900mAh battery with Type-C charging for long-lasting vaping. It has 50mg strength is pre-filled with 22ml capacity to deliver an impressive up to 30K puffs without frequent refills. It support MTL vaping for 30000 puffs and RDL vaping for 15000 puffs. Equipped with dual mesh coils, it brings smoother and denser taste. Featuring adjustable airflow, it can customize your vaping. The 3D curved screen also bring you convenient use.
Details:
iCity CT 35000 Disposable Vape is the first fingerprint touch panel for big puff disposable vape , it can easily open and lock the screen to keep away from children,This 35K disposable vape with Dual Mesh Coils with 2 Modes, It can last for a long time if you stick to the Regular Mode. With RGB big screen display , it can show the battery and capacity balance , and Eco Boost modes, etc.
Details:
The ARYMI Hookalit 40000 is a great disposable vape that balances functionality and aesthetics. It has a large 1300mAh battery, giving you a ton of puffs - up to 40,000! The 40ml of pre-filled liquid means you don't have to refill it often and can enjoy the flavour for a long time. On the bottom, there’s a slide button that lets you adjust the airflow. You can switch between a tighter MTL style of vaping or a looser DL style, depending on what you prefer. The device also has a 0.6ohm LIT mesh coil, which helps make each puff taste great and produces a nice, smooth vapour.
Re: Disposable e-cigarettes recommendation
Příspěvek od xanhast » 03 črc 2025 17:39
Příspěvek od xanhast » 04 srp 2025 06:36
